progressive dvd players...
Discussion in 'Blu-ray & DVD Players & Recorders' started by tonycommander, Nov 1, 2004.
  1. tonycommander
    tonycommander
    Nov 1, 2004
    1,999
    Malvern
    +138
    Anyone point me to a player that would be a good match to my 36 inch panny CRT.
    Has progressive/component inputs, so might as well make the most of them with a new player.
  2. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    I can vouch for the quality from the Denon DVD-2900. I use one with a 36" Toshiba and am very pleased with the picture quality. Worth noting that a good set of leads makes the world of difference, whatever player you choose.
    HTH
    Tony
  3. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    The pio 575 seems to be getting a lot of praise and is a good price. How much are you looking to spend?
  4. tonycommander
    tonycommander
    Nov 1, 2004
    1,999
    Malvern
    +138
    good point about cost...
    not really thought about that, but within reason someting that'll go well with my 36 inch panny and dsp-a2...
    may even consider a recorder to replace my phillips, as we do drop stuff onto that from sky+ now and then... So it might be nice to not have 2 dvd's around the telly.
    But a budget player might be ok, as this telly is only a stop-gap until hi-def arrives and a plasma/lcd is bought!
    At which point I'll re-asses everything.
  5. soulbrother
    soulbrother
    i have got a panny 36pd30 and a denon 2900 which ive got hooked up using a supra av3 componant.The picture is the best ive seen on a crt.
  6. BrianC
    BrianC
    Jan 20, 2003
    2,190
    +101
    I've also got a 36pd30, which, like you, is a stop gap till I go Hidef when Sky release their HDTV service. Mines been fed via a HK DVD25 and more recently via a Denon 3910, both PAL & NTSC progressive scan players. I noticed a big improvement in picture quality stepping up to the Denon.
