Progressive audio delay;what range is needed?
Discussion in 'Plasma TVs Forum' started by nathan_silly, Jul 8, 2003.
  1. nathan_silly
    nathan_silly
    I know using a display in progressive incurs a delay whilst the image is being processed.
    However what is the +/- delay needed? - does one Plasma screen take xx ms and other one needs xxx ms?
    I have the ability to delay 60ms.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,177
    +3,004
    Yes different video processors require different amounts of delay.
    In my experience with 60ms you have enough. Some processors actually introduce over 100ms but with 60 I am sure you will have the bases covered.
    Gordon
  3. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    Gordon,
    As a relative newbie here I hesitate to take issue with you, but...;) Using pal progressive from a Denon 2800MkII into a Panasonic PW4 some discs need as much as 120ms delay to sort the lip sync. Even Sky+ needs more than 80ms though it varies channel by channel. 60ms would not be enough here.
    Piers
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,177
    +3,004
    Piers,
    I think I pointed out that in some cases over 100ms delay is induced. What I said is that even although this is the case in my experience I've never had to go above 60ms to make it not noticeable.........
    I watch Sky channels and my DVD's through a scaler and have NO lip sync delay added. Horses for courses.
    No one shoudl be concerned with taking issue with me. I want to learn too.
    Gorodn
    Gordon
  5. siluro
    siluro
    Jun 11, 2002
    443
    The Original "Garden City"
    I would go with gordon on this one, when i used my NEC plasma and 88+ together the delay is set to 50ms (preset by arcan) and you didnt notice any real problems other than bad disks (if i remeber right fast and furious is slightly out anyway). But as gordon said difrent processing takes difrent times and i would asume internal chipsets would need less delay than eternals boxs.
    just my 2 pence worth tho
    lee
  6. nathan_silly
    nathan_silly
    So some DVD players have digital audio delay function?
    That (selectable?) plus my 60ms on the MC-1 should give me more adjustablility on the final delay.
    Ta
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,177
    +3,004
  8. siluro
    siluro
    Jun 11, 2002
    443
    nice one gordon, i had seen a extra delay feature in the menus but thats whats its for:smashin: , i though i was just somthing to do with the DVD-A thing going on.
    Naihan, as far as i know, and i could be wrong but arcam are the only ones to do a delay feature (even the preset on the 88+), but just a 88 with a sil board should give ajustable delay as gordon says. I think the main reason for this is arcam players are Macro certified on pal pro.
