Progressive and denen AV3803 amp
Discussion in 'Projectors, Screens & Video Processors' started by briandzo, May 3, 2003.
  1. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    If i feed my progressive dvd source
    Denon 2800mk2 player to my denon AV amp 3803
    and then have the 3803 feed the plasma display.
    Will the AMP pass the progressive component source OK?
    The second component souce to the amp will be
    from digi box. (converted via seperate box)
    Will this also not interfere with the Progressive setup.
    Basically is the amp - literally just using relays
    to move the signals around, therefore no problems
    should be encountered.
    all is there some signal processing done first.
    that may effect the progresive signal from the dvd player.
    all sources will be component only
    no up converting reqd.
    I hope this makes sense.
  2. drago.d
    drago.d
    Apr 25, 2003
    168
    Kings Langley, Herts
    +9
    I believe the 3803 will. I asked Denon this same question about my A-11 SR, and they confirmed the prog signal would be passed through , no problem. The video circuitry in the 3803 Denon is a higher spec. than the 3802's, (and possibly my 11SR :( ) - converting composite and 'S' to component, and also a video bandwidth of 100MHz!:smashin:
  3. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    it works,
    i now have all the kit wired up as said
    and all works ok.
    thanks.........
