progresive scan solution for philips 9965
Discussion in 'Philips TVs Forum' started by markus933, Dec 1, 2004.
  1. markus933
    markus933
    Oct 12, 2004
    34
    11
    Maidstone
    Hi guys,
    I was really disapointed with Philips when i realized i could only run a progresive scan signal through the vga port of my 9965.My yamaha dvd player outputs a progresive scan signal through component only so ive been trying to come up with a solution to this.
    I`ve found a lead by Lenexpo that is a vga to component video breakout cable.It says it works with all progresive scan and hdtv signals.Dose anybody think it will work ok or am i throwing good money after bad?
    Thanks guys.
