Progresive scan players
Discussion in 'Blu-ray & DVD Players & Recorders' started by s9s, May 6, 2002.
  1. s9s
    s9s
    Thinking of upgrading my tosh 2109 player, to the 510 tosh, im a bit flimsy on p scan, would i be able to take advantage of it on my tv? My tv is a tosh and has component video inputs.
    Regards
  2. Timh
    Timh
    Sep 14, 2000
    5,267
    3
    3
    Altair-4
    +339
    No! progressive scan is for using on Video projectors and plasma displays only.
    The 510 is a very good player, and you should notice a differance in picture and sound quality, its also a DVD-Audio player. You can still connect it via componant to your tv, you should see a differance in pic quality if you are using composite or s-video, its only slightly better than RGB.
    Do a search for the 510, its been discussed quite frequently lately.
  3. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    I beg to differ sir!
    I'm not sure if the Tosh TV will accept a prog scan signal, but prog scan is no longer just the domain of Plasmas and PJ.
    I.e. Loewe TV's will accepts a prog scan signal via YUV as a few others do, and it is becoming more of a point for manufacturers as RGB scart enabled sockets are.
    Pioneer 503HDE plasma
    Toshiba 900e player
    Denon 3802
    KEF eggs 7.2
    Pronto Pro
    One****ynonpayperviewITVdigitalboxwhichtherenotgettingback
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    I am unaware of any Loewe TV that will accept a progressive scan signal in YUV.....They get YUV through the scart socket and this doesn't support progressive input.
    They can accept a progressive signal through their VGA option socket. This has to be in RGBHV though...not YUV/YPrPb. This is also for UK models. US models will I'd expect accept progressive component....
    Gordon
  5. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    +77
    Thank you Gordon.
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Snowman.....It is very easy to take posts out of context. You posted that the Loewe's will accept a progressive YUV input. My post said they woudn't but would accept a progressive signal in another form.....one which progressive scan DVD players don't usually output... I expect the post of mine you cut and pasted from also explained this...Can't really make it any clearer for you!
    Gordon
  7. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Quite clear me thinks. :cool:
  8. s9s
    s9s
    Thanks ppl, TimH I have read of the 510 on this forum, I think tosh players are the best and decided on the 510 because of its features and reviews.
    On the P scan bit im pretty sure i read something of hdtv being able to accept p scan. My tv is tosh 32zd09b
    One other thing my current player the 2109 (a classic) has a the excellent QED SQART AV 4110 scart onnection, if i was to use component video from the 510 am i going to se a great difference? Or is it better to carry on using the 4110 cable? Seems a shame to leave it to waste.
  9. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    +77
    Sorry :( no offence intended.
  10. JUST BRING IT
    JUST BRING IT
    I've got a plasma - Fujitsu 4222.
    And am thinking of upgrading dvd player.
    If I get one with Prog scan, how do I make use of it?
    My plasma has inputs for:
    1) 3 way component RGB
    2) 5-way RGB (R,G,B,+vertical & Horizontal synch)
    3) RGB (VGA)
    4) S - video
    help?
  11. MoonsSpawn
    MoonsSpawn
    To make use of progressive scan on your Fujitsu, you will need a DVD player that supports progressive scan. These usually have component outputs and you would need to hook it up to the component jacks on the plasma.
    Hope this helps
    Steve.
  12. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    According to here http://www.digitalconnection.com/HomeTheater/pds4222.htm it has the following inputs:
    Rear A/V
    Front A/V
    S-Video
    RCA Audio Input (L+R)
    Component Y-Pb-Pr
    Component Y-Cb-Cr
    RGB1 VGA 15-pin DSub
    RGB2 BNC 5 RGB+HV
    RS-232
    Since the component connectors are there you just buy a DVD player which supports PS. May need to check the PAL/NTSC compability for both, player and display.
