Prograssive scan DVD player to Projector..?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mr. Flibble, Jun 26, 2003.
  1. Mr. Flibble
    Mr. Flibble
    Hello,
    I've a prograssive scan DVD player with component outputs (Teac DR-L700) and I'm want to connect it to a projector (NEC LT240) with a VGA type input. Shall I connect this straight to the projector with a componant to 15pin vga style connector or would there be any benifit putting the signal through something like an iScan first?
  2. magking
    magking
    Jan 6, 2001
    380
    Norway
    The Iscan will probably not give you a better picture than the P-scan out of your DVD player.
    Before you go out and buy the VGA - Component cable, make shure your PJ accepts component in on the VGA.
    My Panny PT AE100 does'nt so I have to use a component to VGA (RGBhv) converter.
  3. Mr. Flibble
    Mr. Flibble
    Great, thanks. It does accept componant in.
  4. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    Why not just use the component sockets on the ae100? :confused:
  5. magking
    magking
    Jan 6, 2001
    380
    Norway
    Because the VGA input is better on this PJ, and I get diagonal lines crossing the picture on component in with my Denon DVD3800.:(
  6. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    Sounds like a pretty good reason to me.:smashin:
