Question Programming YouView remote
hkbs
We have just switched to Freeview/YouView and I have programmed the YouView remote to control our Samsung TV. It works fine for ON/OFF, Volume, etc.
If I press the TV-AV button, the Source list appears and I can move between Freeview and YouView.
The problem is that I can't exit the list without using my Samsung remote, which rather defeats the object of the exercise.
Is there a way to control this on the YouView remote please?
Tom Smart
You do just get this some times, you could try some more tuning codes. Does the source list not just disappear after a period of time?
hkbs
It would help others if you told us how you do exit it?
Sorry, in the Source, I couldn't use the down arrow but realised I had to keep pressing the TV/AV button to move between the options. Then, as Tom pointed out in #2, the list disappeared after a few seconds
