Programming universal remote control to operate JVC hi fi
geoffd4765
I want to programme a Maxview 5 in 1 universal remote control to operate a JVC CA-UXP5R micro system. Does anyone know the 3 digit remote control code for the JVC CA-UXP5R? The code is not one of the universal remote control's preprogrammed codes. I have tried numerous JVC 3 digit codes and I have failed to find the right one. I have seen a picture of a genuine remote control and it has the reference number RM-SUXP5R on the front if that helps.
JayCee
Most universal remotes have a “Code search” function which when activated starts sending a different code sequentially to the device and when the device responds the user stops at that point when the correct code is found.
There's usually a function to interrogate the remote after it's found the code to note what it is.
This function is usually detailed in the booklet that is supplied with the remote.
geoffd4765
Sorry, cat walked across my keyboard before I finished. I have tried the auto code search and manual code search functions and come up with nothing.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
