Programming Humax to Kameleon 6-in-1
Discussion in 'Digital TV & Video Players & Recorders' started by Stinja, Oct 25, 2004.
Tags:
  1. Stinja
    Stinja
    Aug 13, 2003
    12,444
    163
    +3,920
    I dont suppose anyone knows the code for the Humax? the two in the back of the Kameleon 6-in-1 book dont seem to work, and All-for-One's phones were packed on Saturday.
    In the end i started manually adding all the buttons, but while some entered fine others just would not be detected; "ok" and arrow buttons and the play/forward/back/etc ones. I assume this is because it isnt sending the signal continuously or something, but it would be really great if i can program this up - i was trying to get rid of the remote clutter!
  2. jim345
    jim345
    The code for the 8000T is 1427. You may need to download the config.
  3. Stinja
    Stinja
    Aug 13, 2003
    12,444
    163
    +3,920
    Cheers - i'd talked to them and downloaded it yesterday when i finally got through, must be pre-christmas electronic buying time or something?!
    I'll mention that it dosent add the "List" button, but fortunately thats one that can be direct-inputted, and you may have to clear any buttons directly added before setting the Kameleon to 1427, then add/change buttons as needed.
    Back to one controller! :D
