Programme info From Freesat - Loewe Reference 55 TV
yamazaki55
Hi there, I've had this TV for a few years and I'm happy with the picture & sound, but the channel info that comes back from the Freesat dish is a random mess, with no program info etc. Now I have a bit of time on my hands I was wondering if there is and way of sorting this without having to get an additional box.
Many thanks for reading, Adrian.
logiciel
Welcome to the forum.
Is there a reason for not using Freeview instead?
grahamlthompson
Guessing the TV does not have a freesat tuner. It;'s likely to be a generic FTA (Free To Air) tuner.
The first thing a freesat device asks for on setup is you postcode. Once validated it sets up your local channels on the epg. eg ITV-HD on 103 etc.
The actual broadcast does not have the full epg, or a channel number. Only programme info is now/next. The Freesat epg has channel number data and interactive series or one recording.
Only real way to sort it out is connect a freesat PVR requiring two feeds or a single tuner one that can record to a USB drive.
logiciel
The TV is not FreeSat.
It has, as you say, a generic satellite tuner.
yamazaki55
I see thanks for the replies, I don't want to have to get an additional box (will ruin the look) so I'll probably put up with it. It just so happends that the Freesat dish has just gone on the blink, (yes I have tried hitting it with a broom handle). Is Freeview more likely to have channel info? Also, is Freeview HD just as good as Freesat HD?
logiciel
Freeview does of course have programme information.
Dec0R
Sorry but what brand of tv do you have, is it a smart tv. I recently bought a Walker tv, (Vestel) during set up, there is a facility to download a satellite Satcodx channel list, this includes all the main channels in a reasonable order, other than that you should be able to reorder the channels in your preferred order, it might take a bit of time but you end with an ordered list.
yamazaki55
I'll check it out thanks, I have arranged for someone to come round and test if a Freeview ariel will get all the channel info etc.
logiciel
It needs an aerial.
What make and model of TV?
If it is a generic digital terresrial TV then it will NOT get programme info, if it is branded by manufacturer as a Freeview TV then it will gey info
grahamlthompson
Loewe is high quality premium brand (high cost TV) TV ) (f I remember correctly from Germany) .
It has never been a freesat certified TV.
I was talking about Freeview NOT Freesat
logiciel
OP was talking about both.:)
spinaltap
I own a Loewe Bild 7.55. It does not have a Freesat EPG.
You need a suitable/separate box for Freesat. If that box is ‘CEC’ then you can control it with your Loewe remote control.
Podcast: CES 2021 Special - Sony, LG, Panasonic, Samsung, TCL and Hisense TV news and more...
