Programmable Remote Advice Needed
Discussion in 'Home Cinema Control & Remote Controls' started by HMHB, Mar 5, 2003.
  1. HMHB
    HMHB
    Nov 11, 2001
    25,511
    Nottinghamshire
    +3,850
    I really miss the ability there use to be on my old analogue satellite system to flick between 2 different channels with the one button. My question is this - Is it possible to set up buttons on a programmable remote to have channel numbers in - so I could allocate, say 4 buttons for the 4 channels I wanted to swap between that evening and then change them the next day if required to 4 different channel numbers. I would ideally like to do this on a relatively cheap one for all 6 or something like that.
