programing 2 Harmony remotes
colin45
I already have a Harmony 895 and have just ordered an 885. When it comes to program the 885 will I have to install new software or will I be able to use the one that I have.
destix
i believe you can use the same software , on top of that i think its just a case of clicking "update remote" on the homepage and it will setup the 885 exactly the same as the 895 that u have (same devices/setup)
czzer
If you want to use both remotes on different setups, you just need to set up a second user account for the second remote.
clockworks
Yep, same software, but 2 different user accounts. I'm using an 885 and a 525 on one PC with 2 accounts.
Similar threads
