program not responding
Discussion in 'Computer Components' started by grayson, Apr 24, 2004.
  1. grayson
    grayson
    i have a nec 1300a dvdr drive and and a 16x dvd rom drive amd athlon 3200 running windows xp.
    the problem is whenever i use my cd drives with another application 7 times out of ten it locks up so i press clear alt del to end program and it says this.
    Nero is not responding or powerdvd is not responding when i try to end program nothing happens.
    When I play a game though or run an app it works straight away
  2. mjn
    mjn
    May 24, 2001
    22,110
    Herts, England
    +9,867
    i should imagine, either Nero or PowerDVD require exclusive use of your DVD drive.
    Are you using your DVD drive as a "reader" or "source" drive for Nero by any chance?
  3. grayson
    grayson
    im using it as sourse drive for nero, how do i find out if its a reader and how do i set up the drive properly
  4. mjn
    mjn
    May 24, 2001
    22,110
    Herts, England
    +9,867
    if you're using your dvd drive as a source in Nero, then i imagine you can only use either program at a time, and not both at the same time.
  5. grayson
    grayson
    Just looked at the ASPI settings in nero tool and it says ASPI installation is corrupted, what does this mean?
  6. mjn
    mjn
    May 24, 2001
    22,110
    Herts, England
    +9,867
    ASPI is a communication layer between the software and hardware.
    You can download ASPI drivers from the web. Check Nero's website first, then do a search on the web.
