Progessive Scan DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bigga, Mar 3, 2003.
  1. Bigga
    Bigga
    I was due to purchase the Pioneer 757ai DVD, but I have read on this forum that it is only NTSC compatible Prog scan. Can this be altered todo Pal prog scan, or is tere are similar quality (and Price!!) dvd player that will?
    many thanks
  2. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    If you check the various threads on the subject on this forum you wil find a lot of info on such players. Hopefully, Pioneer will offer a firmware upgrade for the 757Ai to add PAL PS. Personally, I chose this player against others with PAL prog because of its overall, features, performance and quality for the money you pay.
