Prog scan ??
G
graham_ew
Will a DVD player such as the Tosh 510 which has prog scan show any upgrade in picture quality when used on a RPTV (no componant inputs) when viewing a NTSC DVD through RGB scart or do you need to use the componant out/inputs to enable this?
G
graham_ew
Cheers for the quick reply Graham,
I thought so , Im after udating my Tosh 2109 and just wondered what benifits I will get straight away ( I do intend to get a projector some time in the future)
G
graham.myers
I suspect one side effect, and I don't know this for sure, is that if you went for a player with proggy scan, I would have thought the manufactures would use better components.
If you're trying to generate a good signal through PS, you then don't want to drag down that quality by using inferior internal components.
So, even if you won't benefit fromp PS initialy, I would have though even through s-video you would see less cross-talk etc.
but i may be wrong
karkus30
Forget the future . Get it now, now, now :D
🎬 The Top 20 Most Anticipated Movies of 2024
Back
