prog scan
Discussion in 'Projectors, Screens & Video Processors' started by DisguisedCoot, Oct 20, 2005.
  1. DisguisedCoot
    DisguisedCoot
    Sep 26, 2005
    797
    46
    swindon
    +127
    What diffrence does having a prog scan dvd player over a normal one, i have just upgraded my pj so it now has component inputs and i want to get the best possible picture.
    :hiya:
  2. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    Where to start... Assuming you have an LCD or DLP PJ, it all comes down to how good the deinterlacer/scaler is in the PJ and whether or not this can be bettered by the deinterlacer/scaler in a prog scan DVD player. It will almost certainly be bettered by a dedicated external scaler (£££).
    What kit have you got? This might allow others to chip in with guidance.
  3. DisguisedCoot
    DisguisedCoot
    Sep 26, 2005
    797
    46
    swindon
    +127
    its a sony HS30, i have just got the multi cable for it that has component input on it. I have all my kit connected via scart to to a swithbox that feeds a rgb to component converter that then feeds the pj. The picture is so much better than the s-video i was using. I just wanted to know wether getting a player with component out would be better. i dont want to spend loads
