Prog scan v component interlaced?
Discussion in 'Projectors, Screens & Video Processors' started by WoodyAllen, May 24, 2004.
  1. WoodyAllen
    WoodyAllen
    Jan 19, 2004
    91
    Northern Ireland
    +4
    Did I read somewhere that picture quality is better by feeding a component signal direct from the dvd player and letting the pj carryout the de-interlacing? :confused: Why should it be better? I've tried both & can't realy discern any significant difference. I'm using a panny 500 & HK 25...
  2. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
    it all depends on which has the better de-interlacer the pj or the dvd. In my case i have a pio757 and an h56 in which case i have been informed the h56 has a far better de-interlacer. Do you know what the de-interlacing chipsets are on your pj and dvd?
  3. Kramer
    Kramer
    In that instance use whichever looks better to you :p
    As said, you're viewing a progressively scanned image either way with the deinterlacing either being done by the PJ or DVD player.
    Seriously, that is what it boils down to - personal preference. You're using the same cable(s) so it should be easy to change from interlaced to progressive (DVD player).
    Whichever looks best to you is (should be) the deciding factor.
    :smoke:
  4. WoodyAllen
    WoodyAllen
    Jan 19, 2004
    91
    Northern Ireland
    +4
    Sorry, I haven't a clue.. :blush: As a novice to home cinema I was unsure if the component feed to the pj would be automatically processed to a prog scan image by the pj - your replies confirm that it will: clever pj.... Kramer, I totally agree with your approach: if it looks good - leave it alone; hence, I haven't changed a single setting on my pj from the factory settings (heresy to some tweekers!). Thanks folks :hiya:
  5. z5461313
    z5461313
    Sep 18, 2001
    1,661
    +241
    I read the AE500 has a very good de-interlacer from reviewers of this projector
  6. Kramer
    Kramer
    I used to be one but have now converted.....
    NOT! :D
