prog scan tosh?
Discussion in 'TVs' started by Vection, Apr 6, 2003.
  1. Vection
    Vection
    Mar 23, 2002
    129
    19
    Over there!
    I hate to do these kind of posts but:-
    can anyone tell me if the tosh 32z17b does prog scan?
    i've done a few searches and can't find any info and the manual is crap.:(
    basicaly i dont want to go hunting for a prog scan dvd palyer upgrade if my tv cant make use of it.
    a simple yes or no will sufice.
    cheers in advance.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    No it doesn't... look out for a DVD player with component out though as this TV has inputs for it ;)
  3. Vection
    Vection
    Mar 23, 2002
    129
    19
    Over there!
    Thanks rct
