Prog Scan question and aspect ratio
Discussion in 'Projectors, Screens & Video Processors' started by scollops, Jan 20, 2004.
  1. scollops
    scollops
    Not sure where to ask this but thought as its to do with progressive ....
    Anyway hooked up the HK 2550 to My plasma (panasonic) - setup up as progressive, select a dvd PAL - screen is 16.9 with top and bottom black borders - cant alter this with aspect changer. If I put the DVD into interlaced all works fine, although the picture quality has dropped.
    Question is, is this normal ?, will the black borders burn in my plasma ?
    How do I get full screen progressive ?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Black borders are a result of playing a film with an aspect ratio that isn't 16:9, eg. 2.35:1, it should make no difference whether the signal is interlaced or progressive.
    Something else is going on here, maybe a setup difference on the player between interlaced and progressive modes, per se the type of signal isn't the cause.
  3. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    What is the film in question?
  4. scollops
    scollops
    Film is attack of the clones - tried a few others similar probs, had a play around with PAL 60 settings and progressive, looks like this is helping - anyone know the best setup on HK 2550 DVD ??
  5. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Well then, it's as KraGorn said, AOTC is a 2.35:1 ratio film. Therefore if displayed correctly it will have black borders, above and below the picture equal to approx 25% of your screen (12.5% top and bottom).
    I can omly surmise that when outputting progressive scan, the output is fixed, whereas in interlaced mode it is possible to change the aspect setup in the players menu. With this menu option if you select 4:3 then you may be able to better fill the screen, but the picture will be of lower resolution and geometrically distorted.
  6. salacious
    salacious
    Nov 2, 2001
    46
    Scotland
    I know with the HDTV screens in North America that some screens automatically go into 16:9 with a progressive input and it cannot be changed. Not sure if this is your problem but it is something that I have read.
