Prog scan query
Discussion in 'Plasma TVs Forum' started by thfcwestlower, Oct 17, 2004.
  1. thfcwestlower
    thfcwestlower
    Sep 26, 2004
    186
    +11
    I have tried searching through similar topics but cant find a definitive answer.
    I am planning to purchase a Panny PW6 and use a quintro switch box to connect Sky+, DVD, X-Box, PS2 and Gamecube via a JS RGB/VGA convertor. WIll this set up give me:
    1) Best pic quality (especially from consoles)
    2) progressive scan (from DVD)
    Cheers in advance for any advice, I know its an amateur question, but really dont have a clue when it comes to AV!!
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Picture quality should be very good, and probably the best you'll get this side of silly money.
    And no, this will not give you prog-scan from the DVD player. You would need to feed the plasma via a component lead for that. Whether this would improve that quality of the picture, compared to your current set up, depends on whether the de-interlacer in the DVD player is better than the one in the plasma. You would be looking at a mid-range player at least to make a significant difference, I would think.
