Prog Scan probs with Denon 2900
Discussion in 'Blu-ray & DVD Players & Recorders' started by too_laid_back, Jul 8, 2003.
  1. too_laid_back
    too_laid_back
    Sep 30, 2002
    38
    Essex
    Guys...
    Was looking around for a Denon 2900... emailed a company for a quote.. who where more than happy to sell me one.. this is what i got back from them..
    A 2900, delivered, with full MR capability would cost you £750.
    However, there is a firmware issue with this machine at the moment - Denon's Multi-Region disc unfortunately disables PAL Progressive scan. Not ideal!
    We should be first to have a fix in about a week. All 2900s are affected - don't buy one now from anyone, even us!
    Is this true???..if so, what is the problem..can't seem to find anything about it.:confused:
  2. Jan_Assembler
    Jan_Assembler
    You would have found this info yourself searching this forum.:lesson:
    But here it goes:
    Current MR firmware disables pal progressive, but you enable it after with remote hack:
    1. Take out any discs you may have in the player.
    2. Turn off player. (On the player...don't use remote)
    3. Press buttons "STOP", "SUPER AUDIO CD SETUP" and "<<(FR)" all at the same time. Keep these buttons pressed and turn on the player.
    4. You'll see "LOADING" in the display. You can let go off the buttons now.
    5. Now you have 10 seconds to finish the procedure or you have to start from the beginning. The rest of the procedure is only possible while "LOADING' is being displayed.
    6. Press "SUPER AUDIO CD SETUP", "PAUSE" and "|<<(Skip Back)" in this order and hold these.
    7. You will see the "VSS Icon" flash in the display.
    8. Let go off the buttons and "0:00:00" will be displayed.
    9. Turn off the player. (On the player...don't use remote)
    When turning it back on PAL progressive will be enabled.
    :D
  3. thewall
    thewall
    Jul 9, 2003
    27
    Got a disc today and popped it in. It took about 20 seconds then it was multiregion. Did not take away prog pal. Only set everything to factory default.
  4. therecanbeonly1
    therecanbeonly1
    Dec 25, 2002
    92
    Gold Coast, Queensland
    Where do you get these discs?
  5. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    I ran the firmware upgrade on mine - like thewall says, took about 20 seconds. I was warned that it would remove PAL progressive and had already been given the instructions Jan listed, so I did them straight away after the firmware - I must admit, I didn't actually check to see if the upgrade had removed the PAL progressive, but it certainly works fine now! Great player BTW - really impressed - both NTSC and PAL progressive pictures look really nice and the audio side is fantastic! I had no idea how much of a difference a DVD player could make to the audio side of a HC setup, but this one certainly has! :clap:
  6. toonarmynufc
    toonarmynufc
    could i borrow your multi region disk
  7. Vorlon
    Vorlon
    I got my Denon from Nexnix for £580+vat, seems to be ok and plays multiregion no problem. will check for prog scan issues tonight.
    Vorlon
  8. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    Have a look at this link
    http://www.afdigitale.it/edisport/a...5b1d0e52f86609a8c1256d5e004edbef?OpenDocument
    download the file PDH29VND.CPN
    burn the file on to a blank CD
    Open the DVD2900 drawer , insert the new disc, press close.
    The front display on the 2900 will show progress writing new firmware.
    When it is finished the drawer will open.
    Switch off main power switch. Switch on again and its done.
    Multi region and progressive scan works.
  9. therecanbeonly1
    therecanbeonly1
    Dec 25, 2002
    92
    Cool THX:clap:
  10. toonarmynufc
    toonarmynufc
    thanks alot works 100% cheers:smashin:
  11. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Have just bought my 2900 and it should be arriving mext week :D
    I am keen to perform the multi-region firmware upgrade but am also a little concerned about what happens if something goes wrong.
    I notice several people have successfully performed the upgrade...has everything been okay since ?
    Also, can anyone provide a link to the un-moddified firmware just in case I should want to go back.
    Cheers, Lee
