Prog scan on Arcam FMJ27A
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bobole62, Jun 24, 2003.
Tags:
  1. Bobole62
    Bobole62
    Just brought an Arcam FMJ27A to go along with my AV8 /P7 set up but am having trouble with the prog scan on my hitachi plasma.
    When I try to use the prog scan outputs the top of the picture becomes blurry. I know my plasma accepts prog scan input but have heard that some plasma's need a vertical / horizontal sync.
    Anyone know how I should set that up? or has anyone else had a similar problem
  2. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    This may well be better suited to the DVD Player forum...
    K.
  3. Bobole62
    Bobole62
    Ok, thanks
  4. jmack
    jmack
    hi i might be wrong but i dont think its your dvd player fault, your hitachi plasma has a ALIS screen which if i`m right prefers interlaced signals to progressive ,
    why not post the question on the plasma threads aswell?
  5. jont
    jont
    Apr 8, 2002
    3,906
    near Aylesbury
    +409
    You may need to check the setup on the DV27 as to how it is putting out its prog scan/sync *and* the setup for the inputs on the plasma ...
    Are you using phono, or bnc or vga for input into the plasma ?
    does the cabkle have separate composite/h & v sync leads ?
    I had to make sure both were setup the same ... btw I use 3 x phono for component out of the DV27 into the AV8 and then 3 x phono from AV8 to plasma (with three phono>bnc converters on the end) ... set to sync on green ...
    rgds
    Jon
