prog scan nebie, help!
jamiev
hi, i am thinking of purchasing a z2 pj and want to know how to upgrade to pal prog scan?
ie: what dvd player do you recommend?
what connections ARE REQUIRED TO PJ? PRESUME COMPONENT?
what dvd's do i need to buy? region 1 only?
thanks
:clap:
T
TimF
If you want a DVD player that outputs prog. scan your post will get more replies in the DVD player forum.
Component video leads will be required and you will be able to play any Region disks and not just R1 (NTSC) and benefit from prog scan.
Tim
KraGorn
Jamie:
What budget do you have? At the bottom end a Sony 730 is very nice with a Z2. Such a player will use a Component connection.
Alternatively you may want to look at a cheapish player with a DVI output, have a read of this thread in the "DVD Player" forums.
Use of progressive doesn't mean R1 only, that'd only be the case if the player you bought only did progressive output for NTSC, which indeed some (most?) do, but the 730 or something like a Harmon Kardon 25 do both.
As Tim suggested, you'd be better off posting this in either the LCD PJ forum or the DVD Player forum, probably the former.
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
