Prog. scan loewe??
Discussion in 'General TV Discussions Forum' started by Spunky, Apr 29, 2003.
  1. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    Does anyone know if any of the loewe models support prog scan, either Pal or Ntsc?
    I've been reading the blurb from the loewe website and get this:
    Also does anyone know of the benefits of using the optional VGA module that can be added, does it offer any benefits to the picture quality??
    The reason why i'm asking is that i'm eyeing up the new Tosh 36"picture frame 2 (with prog scan) and the 32" loewe Aconda- dont know might get a different model, still unsure.
    I know the loewes have got a lot better build quality, but will it offer a better picture than the tosh??
    Cheers all
    Spunky
  2. Jagsta
    Jagsta
    The vga module has been discussed quite a bit recently and in the past, do a search for loewe and vga on the forums.
  3. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    Should have done a search earlier, really.
    Sounds good but it think i'll have to weigh up the benefits of the loewe against the tosh and view the two side by side.
    Spunky
