Prog scan for £40? Wheres the sting?
Discussion in 'Projectors, Screens & Video Processors' started by nunew33, Oct 16, 2003.
  1. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Lookie here
    I know its limited resolution but isnt the outcome the same resolution as a progressive scan DVD player?
    So for £40 would this give a better than average image to non PS DVD/Sky and VHS VCR?
    Anyone know anything about this product?
  2. franc
    franc
    Sep 12, 2002
    450
    Bucks
    +7
    Hi.
    I picked up one of these some months ago and was unimpressed.
    Using the component input (highest quality) the image displayed a bright green vertical band on the left hand side of the image (about 10mm wide).
    The mythical product you seek i.e. inexpensive and good quality de-interlacer/scaler does not exist the happy side of £250....
    regards Franc
    regards FRANC
