Prog scan DVD players
Discussion in 'Plasma TVs' started by Supersonic72, Apr 14, 2005.
  1. Supersonic72
    Supersonic72
    Jan 10, 2005
    244
    What difference does it make, if any, if a DVD player doesnt have Progessive scan??
  2. Supersonic72
    Supersonic72
    Jan 10, 2005
    244
    ..In context, as regards playback on a plasma display?
    Does it matter, or is progressive output better, no different, or worse?
  3. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    Depends on the plasma - if it's an ALIS plasma then, IMHO, the progressive picture looks no better than non progressive.
    If it's a non ALIS panel then progressive should look better.
    John
  4. Selectortone
    Selectortone
    Nov 18, 2002
    70
    It depends on the DVD player.
    The consensus here seems to be that the PS processing on a £1.5k plasma panel is likely to be better than that of a £100 DVD player. With a £500+ player try both ways and let your eyeballs be the judge.
  5. Supersonic72
    Supersonic72
    Jan 10, 2005
    244
    The last comment is much as I thought...the panel is likely to be better at it then the DVD would be....
    Secondary question then...so what about RGB scart? Is a DVD player without it going to be much different to one that has???
