prog scan dreamcast
Discussion in 'Nintendo Forums' started by bash, May 2, 2003.
  1. bash
    bash
    Nov 10, 2002
    2,936
    London
    +609
    Apparently the output on most Dreamcast games are 480P if used in VGA mode ie on a monitor.
    my question is would it be possible to make a component cable for the dreamcast to use on the Tosh xxZD26 for prog scan games? Or indeed, get a VGA to Component adapter to do the same thing?
  2. kwangomango
    kwangomango
    Jan 9, 2003
    859
    Kent
    +38
  3. bash
    bash
    Nov 10, 2002
    2,936
    London
    +609
    Wowzers! that stuff aint cheap. . . . looks like Im stuck with RGB then:confused:
  4. NeoBlade
    NeoBlade
    You can of course make a component box yourself but it won't be cheap... Plus without the right skills it would take some time ^_^ Worth doing if you have the ability though. Right now I'm just making a case for all of my consoles as I'm running out of space...
