Prog Scan cheap alternative question
Discussion in 'Projectors, Screens & Video Processors' started by CooperUK, Oct 19, 2003.
  1. CooperUK
    CooperUK
    Jun 30, 2003
    2,166
    Hampshire
    +287
    I am looking for a relatively inexpensive way of getting prog scan and would like your opinions is this any good?
    Cheers,
    Coop
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,695
    Norwich
    +606
    what are you plugging into ??? and what are you plugging into it ???
  3. CooperUK
    CooperUK
    Jun 30, 2003
    2,166
    Hampshire
    +287
    I would be running a Panny AE100 from a Sony DVD player and Sky Digibox via s-video cable.
    There is only one s-video cable as the devices concerned are switched via my AV amplifier.
    Any help would be greatly appreciated!
    Coop
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,695
    Norwich
    +606
    I would put money on the de interlacer in the panasoinc being far to superior to the de-interlacer in the link you provided.
    I think unless you are going to add somthing like a lumagen or better then you would be wqasting your money mate.
  5. CooperUK
    CooperUK
    Jun 30, 2003
    2,166
    Hampshire
    +287
    OK, cheers for the information.
    Have to save up for the iscan or similar!
    I have spotted a Prov+ for sale that seems tempting and more in my price range.
    Coop
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,695
    Norwich
    +606
    I would have still thought that you would be better with a scaler that matches the native resolution of the projector.
    I think that the scaler is a major problem on the Panny, I would look at saving for a lumagen or waiting for one to come up second hand.
    Or maybe spend the money on a better projector, you will see bigger gains by using a PJ with a decent interlacer and scaler and a higher contrast ratio than you will probbably spending the same amount of money on scalers etc.
    I gave up and went CRT, got sick of trying to get an image that was already out there, by buying bits for my DLP.
    Depends if you have the room though.
