R RON Standard Member Joined Sep 20, 2002 Messages 73 Reaction score 0 Points 30 Location uk Oct 15, 2002 #1 can progresive pal be sent to a philipa 9607 through rgb scart or migiht it happen in the future
J Jonny1973 Guest Oct 22, 2002 #2 Progressive signals are only outputted through component sockets. Any device that can handle progressive must have these. As far as I'm aware, there are no TVs in the UK that can handle progressive.
B Big_AL007 Guest Oct 22, 2002 #3 The Panasonic TX32PH40 can handle PAL prog scan through its components, I have one.
S sr78 Standard Member Joined Sep 26, 2002 Messages 282 Reaction score 2 Points 49 Oct 22, 2002 #4 Toshiba has one that can do it, too.
mutley Standard Member Joined Jul 28, 2002 Messages 450 Reaction score 2 Points 122 Age 45 Location Portugal Oct 23, 2002 #6 the toshiba strata 32ZD26. It's a beauty!!
B Big_AL007 Guest Oct 23, 2002 #7 It does NTSC prog scan and it is good at it, however it DONT do PAL prog scan.
mutley Standard Member Joined Jul 28, 2002 Messages 450 Reaction score 2 Points 122 Age 45 Location Portugal Oct 23, 2002 #8 i really think that if the dvd player outputs pal progressive through the component output to the component input on the tv that accepts progressive scan, it doesn't matter if it's NTSC or Pal cause the tv will do it both. (not sure)
B Big_AL007 Guest Oct 23, 2002 #9 It does matter, there is plenty of evidence on this forum to confirm this. Would be great if it did as there would be much more choice, alas.....
