ProFoam - Room Acoustic Treatment
Discussion in 'Home Cinema Speakers' started by Boris Blank, Nov 8, 2003.
  1. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,711
    Outpost 31
    +170
    Wondered if anyone tried ProFoam for acoustic treatment in rooms? Seems to be a lot cheaper than Auralex (the UK price for which is double the US price :rolleyes: ).
    Only found one review in this forum by Allan Probin but wondered if anyone else had tried it or if Allan has any more updates on his experience with it.
    I have had problems with echo since setting up my HC room and I'm ready to tackle them at long last!
    Links to ProFoam;
    Panels - http://www.customaudiodesigns.co.uk/absorbers/profoam.htm
    Room Kit - http://www.customaudiodesigns.co.uk/absorbers/siab.htm
    Thanks,
    Paul
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I hear a rumour that they may be an interesting Power Buy of acoustic room treatments soon so don't do anything hasty and full details will be revealed soon.
  3. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,711
    Outpost 31
    +170
    Excellent, thanks Ian! I'd be very interested in that indeed:smashin:
    Paul
  4. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Check out the forthcoming powerbuy Paul!:smashin:
    Although it's not that much cheaper than Auralex, you can get either the Alpha 1 or the Alpha DST kit online for £410 (incl VAT) which compares well to the standard SIAB polyflex kit for £360 (excl VAT - ie £423 all told).
    I've recently installed a D36 kit in my listening room for the princely sum of £170 and can vouchsafe for it's effectiveness.
  5. Parmenion
    Parmenion
    Feb 6, 2002
    1,171
    Out there
    +28
    What on earth is a D36 kit..........?
    and as for the Alpha 1 and the even more fabulous Alpha DST....... where are these to be found?
    Basically........................what are you talking about?
    please help......
    regards
    Parmenion
  6. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,711
    Outpost 31
    +170
  7. Parmenion
    Parmenion
    Feb 6, 2002
    1,171
    Out there
    +28
    My eyes have been opened.
    Thank you
    Regards
    Parmenion
  8. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    Paul - I had major echoes and a very bright room till I treated it, I went with the 2" Pyramids from Auralex and the change is startling. Room treatments should be the first thing on anyone's list for home cinema, you'll see what I mean when you hear the difference.
    Phil
  9. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,711
    Outpost 31
    +170
    Hi Phil,
    I went round the house doing the "clap" test, the worst room is of course the HC room :( I knew that I had problems but hadn't realised just how bad it was.
    I had a look at the Auralex but the Profoam looks to be better value. Roughly the same qualities but the Auralex is more expensive ( in the UK) for what you get. No question that either brand will do the job though and do it very well.
    Roll on the PowerBuy (hoping its for ProFoam!)
    Paul
  10. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    As well as RPG and Auralex there's Primacoustic importred by Sonic Distribution who do full room kits. Also there's Sonex, Soundsorba and on and on.
    CPC, RS and Studio Spares have some own brand panels that seem to work out cheaper than branded ones.
    To make my life more complecated I've contacted a few 'foam convertors' to see if and what they can supply to my own specifications.
  11. rigman
    rigman
    Dec 14, 2000
    2,763
    83
    East Yorkshire
    +59
    Anymore details on this or was it just a wind up?
  12. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Not a wind up but not all Power Buys come off for a variety of reasons. I will enquire further about this one.
  13. rigman
    rigman
    Dec 14, 2000
    2,763
    83
    East Yorkshire
    +59
    What happened to NicB's post with the link? :confused:
    I saw it and thought I would check it out later but is gone. Must have imagined it :rolleyes:
  14. NicolasB
    NicolasB
    Oct 3, 2002
    6,070
    Emily's Shop
    +669
  15. rigman
    rigman
    Dec 14, 2000
    2,763
    83
    East Yorkshire
    +59
    Thanks for that Nic
    I will await word from IanJ about whether the power buy is going ahead before I make an order
