profigold pgv789 cable dimensions?
Discussion in 'Cables & Switches' started by Bascombe, Oct 20, 2004.
  1. Bascombe
    Bascombe
    Jun 1, 2003
    122
    +4
    Yup, its another 10m scart thread......
    :lease:
    Have scoured the forums for info on decent 10m scarts, and have seen the profigold pgv789 (flat cable) mentioned, and for what seems like a reasonable price at tvcables.co.uk. At the mo, I have a very basic round scart lead running along the bottom of the skirting board, and I'm wondering how broad the pgv789 cable is? is it pretty darn flat? Easily tucked under carpets or under the bottom edge of skirting board??
    ALternatively, has anyone else chanced across a decent 10m scart cable anywhere online? I've turned up plenty of anonymous 'gold plated' scart ones, but nothing else (apart from an ixos one over £100, and while I appreciate its probably a pretty fine cable, there are limits) .
    Any info would be greatly appreciated.
    Cheers,
    Bascombe
