Profigold PGV7500 RGB Only?
Discussion in 'Cables & Switches' started by Tofu, Mar 15, 2005.
  1. Tofu
    Tofu
    Hi Guys,
    I just bought one of these heavy scart to scart (RGB only) cables today and found that it displays only composite on my CRT. I've tested other RGB Scart cables with no problem. Has anyone come across problems like this before?
    My setup: Denon 500SD (RGB Scart Out) - to - Philips 32PW9509 (RGB Scart In).
    Does having an RGB only scart meant only for sockets that support just RGB input and not RGB and Audio(AV)?
    I'm confused all my other QED/IXOS RGB (AV) cables work fine except for the mega expensive RGB turned composite Profigold. :(
  2. jzak
    jzak
    I have today! Pin 16 (RGB Mode) has no connection. Probably this cable is meant for equipment that only receives RGB and needs no signal to switch to rbg. Has anyone tried to take the connector appart. It could be easily fixed by replaced composite with RGB mode signal.
