Profigold PGV7000 Oxypure High Def Scart
Discussion in 'Cables & Switches' started by LiquidTV, Nov 4, 2004.
  1. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    Any comments on how this lead performs. It's all too easy to get carried away (I have already!!) spending hundreds of pounds on leads. However, I'm after a decent scart lead to connect from Sony DVD to my Sony CRT TV. This particular lead seems to perform well. I don't want to spend more than £50 if possible.
  2. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    Come on guys, don't let me down...I have also been considering the IXOS XHT611 range. Any thoughts. reviews etc??
  3. Legin76
    Legin76
    Aug 10, 2003
    58
    I've just got one of these today. I can say that there is cetatinly quite a bit improvment between that and the standard cable. When connected between my sky box and projector it's less noticable than on my TV, I can certainly see better colours and the picture is sharper. I've not tried any other cables but I don't think there could be much more of an improvment.
    I got mine from here as well as the oxypure component cable, it was free delivery and they arrived next day :D. I can't really review the component cable though as I've not got anything to compare it against. See http://www.avforums.com/forums/showthread.php?t=160998
  4. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    Thanks Legin76,
    Anyone provide any comments regarding the IXOS?? WHich of the two performs best??
  5. bobbypunk
    bobbypunk
    Not tried the cable you mention.
    For about £50 you can get change buying a Ixos XHT601 which is an excellent cable, you won't get much change but the QED Sqart or Audioquest G-Scart will give a significant improvement.
    And if you push a little bit further you should find VanDenHul's THESCART and Audioquest's X-Scart Which will reward you for the extra.
