profigold pgv332
Discussion in 'Cables & Switches' started by mort, Jan 18, 2005.
  1. mort
    mort
    Sep 5, 2002
    102
    wigan
  2. saintalan
    saintalan
    Dec 7, 2004
    528
    28
    Windsor
    +47
  3. saintalan
    saintalan
    Dec 7, 2004
    528
    28
    Windsor
    +47
    Between posting this and checking out £8 delivery has been added. Think Mort might have had the advantage of a slip!
  4. mort
    mort
    Sep 5, 2002
    102
    wigan
  5. MidnightOwl
    MidnightOwl
    Jan 19, 2005
    122
    +5
  6. mort
    mort
    Sep 5, 2002
    102
    wigan
    hi midnight
    got mine delivered took about 5 days i couldnt understand the other poster who said they stuck an extra 8 quid on deliverey :confused: can only think it was because he was ordering more gear at same time anyway the profigold cables are a really solid performing set of component leads (i already had some so knew what to expect) i have them running at the moment from an old toshiba dvd to my new tosh dlp tv and quality is spot on yeah theres prob better leads about but that usually means 3 times the price :laugh: and like you i think £25 is about my limit on connections but i do think that they more than hold their own and at this price i think they are a good buy
    mort :hiya:
  7. avanzato
    avanzato
    Jan 21, 2003
    1,879
    Norfolk
    +60
    I ordered a 0.5m profigold phono cable from them (Beyond Hifi) yesterday and it turned up this morning. That's fast service.
    The postage is worked out on weight and the more you add the higher it gets. There is an £8 courier delivery option so either saintalan picked that one by mistake or that's the max they charge for delivery.
