Profigold bannanas any good?
Discussion in 'Cables & Switches' started by rmask, Sep 22, 2005.
  1. rmask
    rmask
    Mar 25, 2005
    115
    +4
  2. MyBoxLife
    MyBoxLife
    Jun 15, 2005
    2,663
    Birmingham
    +135
    Don’t think there’s much gain to be had, if any, with the different plugs available, it’s more to do with tidying-up the connections / ease of use, good if you find yourself often moving your stuff around. I’m sure somebody more technical will come along and correct me if I’m wrong!
    Saying that, I picked-up some Vivanco 4mm plugs, only to then notice that my Receiver, Pioneer AX5Ai, has some black plastic stoppers that prevent me from using the plugs, haven't had the push to see if they're removable yet :rolleyes:, so you might want to check your gear before buying.
  3. Dankeech
    Dankeech
    Feb 1, 2005
    3,624
    Stevenage, Herts
    +298
    I have used Gale Gold-plated banana plugs which are very similiar and although I found it gave good contact to the cable, after a while the cable still oxidises.
    The cables themselves on bananas normally attach in from the side of the banana and are clipped or the thumb-screw is turned to tighten the cable in.
    I would highly recommend the QED Airloc banana plugs which are attached in your local Hifi shop using a special tool which seals the cable airtight into the plug, meaning a better contact, better looking solution that won't give you oxidised cables after a couple of months.
    Airloc plugs are normally £5 each fitted from your local hifi retailer, though if you bought cable online, you could get them for £4.25 each fitted on the cabling you order.
    Check out
    http://www.qed.co.uk/cables/speaker/airloc.html
    for more info
    http://www.qed.co.uk/cables/speaker/original.html
    for a pic of an airloc'd cable
    If that is out of your price range, then I can say profigold are good at the price. Have my car auio cabling all profigold..
    Hope this helps,
    Dan.
  4. rmask
    rmask
    Mar 25, 2005
    115
    +4
    You should try to remove plugs on your pioneer
    My denon was also covered
    Just use some strong thing blade knife or screwin some small wood screw and pull it out with plyers
  5. MyBoxLife
    MyBoxLife
    Jun 15, 2005
    2,663
    Birmingham
    +135
    You've got to keep of the drugs my friend! :rolleyes: :D
  6. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    http://www.satcure.co.uk/accs/page13.htm
    Gold 4mm Banana Plug with 7mm (0.25") cable hole at side. Knurled securing screw.
    AV00065 Black collar & AV00066 Red collar :
    B008 Gold 4mm Banana Plug pair £2.10 / £4.20 for 4
    [​IMG]
  7. Dankeech
    Dankeech
    Feb 1, 2005
    3,624
    Stevenage, Herts
    +298
    Good price on those banana plugs though. pretty impressed. Ones pictured on the last post seem pretty much identical to the Gale ones I had @ twice the price.
    Still love my Airlocs too and they'll prevent the cable deteriating over time, better contact etc
    , but good price on the banana's. Think I'll pick up some anyways as they'll no doubt come in handy at some point
