Profigold Banana Plugs
SadR0bot
Just received some profigold banana plugs in the post this morning.
Never done this before so can anyone point me in the direction of how to use these? I can see a screw when I look down the end but how do I get to it?
Do the plastic covers just push off?
R
recruit
Try unsrewing the plastic covers and it will have an insert for the cable with tiny screws to tighten the speaker wire to the plug then screw the cover back on.
R
recruit
I would of thought approx 10mm of stripped cable would of been sufficient or untill it stops.
