Proffesional Slideshow CD - Can I print individual photo's?
Discussion in 'Photography Forums' started by Pebble, Jun 3, 2005.
  1. Pebble
    Pebble
    Nov 18, 2003
    311
    Grangemouth
    +4
    Hi all,
    Is there any way to get individual picture's from a C.D. slideshow made from a proffesional photographer?
    I had a proffesional shoot done for the kid's, which I bought some photo's + he gave me a C.D. with the full shoot on to play as a slideshow on the P.C.
    Is there any sort of software that will let me decrypt the slideshow so that I can print some more individual photo's myself insted of paying through the nose for them?
    I have tried DVD Decrypter, but that only works with DVDS obviously
    Pebble
  2. T0MAT01
    T0MAT01
    Dec 25, 2004
    2,382
    113
    Devon, Sussex or somewhere inbetween.
    +552
    Do you know what format the pictures are in?
    If you open the CD using explorer (right click the select explore) are all of the pictures individually listed or is there one big slideshow file?
  3. S2K DG
    S2K DG
    Nov 2, 2004
    265
    +18
    Chances are the file sizes will be too small to get a decent print from anyway
  4. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    If the CD has no picture files you can just open you can always do a screen capture to have what you see saveable/printable.
    alt+PrtSc will capture the active window... ctrl+PrtSc will capture the entire screen. The capture goes to the clipboard so you then need to open your graphics program of choice (or even windows paint) and paste in the image. Then you can do what you like with it. It will never be very high res but better than nothing.
    If the pro was savvy then the CD is likely to be locked against getting the image files without paying him.
  5. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    get more copies of pictures you want off the guy. SIMPLE
  6. Pebble
    Pebble
    Nov 18, 2003
    311
    Grangemouth
    +4
    Hi guys,
    tried everything you said - dosn't let me alt +Printscreen (author dosn't allow copying of any graphical info)
    looks like its a no go
    Thanks for your help
    Pebble
