Thanks for the advice but it's nothing as technical as radiograms. We have a couple of baked bean cans here with a long piece of string and just need someone with the expertise to make the necessary holes and tie nice knots.
Hi Chris, initially it's just a half days work at a College in Norfolk next week - hence I need someone local really. If you have to travel a fair way to get to site then I'd imagine the rate would be too high?
Likely so, yes. If it's nothing complex and you know enough to guide them, get a local sparky on it. Unless anyone else can step up? Seem to remember one of the isntallers on here is from your neck of the woods.
