Produced film streaky
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by magiles, Oct 4, 2004.
  1. magiles
    magiles
    Hello,
    I am using Videowave 5 and my captured clips play great - no dropped frames etc.
    When I come to produce the storyboard I hit problems.
    The film distorts slightly - usually when there is movement onscreen. The object moving will have streaky lines on it. Is it something I can rectify using the options before you start to produce.
    eg - I think I have it as MPEG to MPEG2.
  2. Roy Mallard
    Roy Mallard
    sounds like the classic field dominance problem, I don't know the package you use, if you have an option in capture settings change the field preference to lower field first or upper field first (depending on what setting you are on at the moment).
