OK... just setting up my TV room. Just need a 3.1 setup for Sky HD and the odd movie - got a dedicated cinema room for the full on stuff...
Kit I already have...
Samsung UE55ES6560U 55" LED TV
3x Genelec 6010a Active Monitors
REL Storm III subwoofer (ancient)
I plan to hook the audio components up to the TV via the ARC HDMI port on the TV.
I'm missing a processor that is ARC compliant. Any recommendations??
Don't need an amp (all the speakers are active)
The only must have is I would really like a very small footprint processor - smaller the better - just want to tuck it away and not be seen. Oh... and I'd like it to be cheap as possible - looking to just use the great speakers and TV without adding too much extra cost.
Anybody recommend anything? Budget £300, but if I could spend less, that would be great!
Many thanks!
Many thanks!
