Process Killer
Discussion in 'Desktop & Laptop Computers Forum' started by WBC, Sep 20, 2003.
  1. WBC
    WBC
    Guys,
    I'm about to render a wedding video ready for DVD. Various websites suggest running a 'process killer' on your pc to free up as much resource as possible for the Video software.
    Anyone know of a descent one?????
    I've just downloaded something called magicutils2003 and I could have just as well killed the processes with Alt+Ctrl+Del!!!!
    All input welcomed!!!!
    Stace :D
  2. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    There's a program called EndItAll - a search on Google should find it.... it's supposed to do all sorts in a click... not really used it myself yet though.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,355
    Rainham Essex
    +2,441
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,355
    Rainham Essex
    +2,441
    Or to save all the faffing around registering etc PM me your e-mail address and I will e-mail it to you.
    Mark.
  5. WBC
    WBC
    Thanks for your help guys.
    'EndItAll' is the one they talked about on a few different websites. Couldn't remember the name and the website was down so couldn't check.
    Just done a google search and it mentions EndItAll2!!!
    I'm guessing its the same just a later version.
    I'll give it a go.
    Thanks Again
    Stace :D
