Procella Audio Speaker Thread
burtonpark
Topmetom 2
Maybe i was thinking like that as well, an introduction. If theyd of been p6 i probably would of jumped. I never got the price list so have no idea on costs etc…
Lesmor
I thought Rich sent you a price list ?
hard to pin down prices but I guess a P6 is around £1450.00 to £1800
there is a fair markup on Procella so there should be some leeway on price
as they would be more of a match I could always try and sell my KK Quattro's and get P5 for heights
Topmetom 2
No, never got anything.
callahan
P6 MK2 is £1800 including taxes and P5 is £995 from when I bought mine.
callahan
@Lesmor I think the P8 would work in your room, they can do full THX levels up to a 6m long room and 4m to main listening position. P28 would be even better I suppose, but not absolutely necessary. Couldn't you build out a small baffle wall just where the screen sits, so you have enough depth for the speakers?
Lesmor
thanks for the response it is appreciated
I agree for L/C/R it would have to be a minimum of P8
a P8 is 200 deep by the time you allow for a bit of clearance
2 layers of plasterboard
1 layer of MDF plus 1" of acoustic treatment
plus clearance from the back of the screen I would lose a fair bit of room length which then pushes my room close to being square which acoustically would be unacceptable
aesthetically it would be great to hide the centre and get the L/R speakers on the wall each side of the screen
to be fair the easiest solution is just to accept my existing compromised centre speaker position
everything sounds fantastic and its hard to imagine it sounding better
burtonpark
Good suggestion but that’s a lot of upheaval for only the centre speaker behind the screen
burtonpark
MSO Multisub Optimiser with the Trinnov +4 and peq filters worked a treat for me, worth trying
Topmetom 2
Agree lot of aggro for the center only. Tbh im now looking for stands for my 1723s for when we move
callahan
True, hiding speakers is always a pain to do, I don't think you'd need much more than 200mm depth though and it could be a fairly simple wooden frame the size of the screen. It's worth it if they sound as good as (my) Procella system though!
Lesmor
a easy option is just to move the screen forward and hang the speaker on the wall but from what I have read the screen needs to be 300mm from the speaker
to mitigate comb filtering the whole area behind the screen needs to be acoustically treated
how is your baffle wall constructed ?
callahan
What screen is it? Does the manufacturer recommend 300mm?
Mine are build into a cabinet as I have a solid projection screen and a TV. I have done what I can in terms of filling in the gaps with acoustic wadding etc around the speakers, but it's far from an ideal setup.
Lesmor
Thanks for the feedback
any pictures ?
in this hobby there are always compromises
the screen manufacturer does not make any recommendations but carrying out due diligence and research,
to prevent the screen moving with sound waves a suggested 300 clearance but that depends if is a perforated or woven screen
researching a baffle wall brings up all kind of issues, a THX baffle wall would be my target
but some people just build a false wall with nooks for the speakers and a large space behind it and call it a day
IMO that could have its own issues
so there is no easy solution
Conrad
I have just glanced over MSO never looked into it in any great detail?
Well worth looking at. I got better results with that in my room that I did manually.
I think I looked at/helped you with your current config, I'd be happy to help again if you want to dive in on the MSO thread.
It's a bit of an art rather than a science getting it to behave the way you need it to, but there's plenty of good info and after a couple of runs you should have a good handle on it.
callahan
Lesmor
yes you were kind enough to look at my REW data a few times and make some useful suggestions
I keep hoping Trinnov release the promised subwoofer update
since getting the Trinnov I just ran the Optimiser and haven't touched REW to verify the results so I suppose it is well overdue
I will have a look for the MSO thread
thanks guys I am off out so will be back later
Latest News
T+A announces Solitaire T headphones
  • By Ian Collen
  • Published
Audio-Technica launches ATH-M20xBT wireless headphones
  • By Ian Collen
  • Published
Focal and Naim announce new Special Edition Ash Grey system
  • By Ian Collen
  • Published
Marantz launches CD 60 CD player
  • By Ian Collen
  • Published
