Proceed AVP & PAV line voltage change
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by David Surjono, Dec 25, 2004.
  1. David Surjono
    David Surjono
    I've got an AVP and PAV that bought from US, when I tried to change the voltage from 120 to 220 , i found out that i need somekind of code to change a line voltage for both of the unit. Please help me with this matter if somebody got the code number.
    Regards
    David Surjono :lease:
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +644
    I know someone who is wel into Proceed gear, I will send him a text and see if he knows, probably won't get an answer till tomorrow earliest though.
  3. David Surjono
    David Surjono
    Thank Sir,
    I'm really appreciate that
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +644
    Got an answer but unfortunately didn't really tell me much, he said that with every bit of proceed kit he has had, that it has just been a case of changing the jumpers inside the unit for 110v or 220v.
    Where did you get them from, do they know??
  5. David Surjono
    David Surjono
    I just bought the unit from US, I have already change the jumper inside but they requiment some code number to change the line voltage, maybe if I bought a power amp it only need to change the jumper. But thank you very much I'm really appreciate it.
    Regards
    David Surjono
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +644
    No problem David, sorry I could not have been any help, hope you get it sorted, and soon, would drive me nuts having new kit and not being able to play with it. :)
  7. Peter Baker
    Peter Baker
    Sep 6, 2003
    621
    28
    LONDON
    +37
    Hi, I use the AVP/AMP5 setup, but bought it in UK so it was already 220. Nothing in the manual either.
    Try calling Mark Dolbear on 07799 186312 or e-mail mark@highendworkshop.wanadoo.co.uk
    He was the Proceed engineer in the UK and now operates an independent repair and upgrade service called High End Workshop.
    He should be able to help ( and is helpful)
    Regards
    Peter
