Prob's with DIY PC
Discussion in 'Desktop & Laptop Computers Forum' started by Jed, Jan 25, 2003.
  1. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Having mega problems,with DIY PC.
    I had everything plugged in to their place's,crossed my finger's,flicked the switch and Wallar......Nowt.Not a light not a fan nowt.
    The only thing i hear when i put my ear to the PSU is a click when i switch it on.
    I have unplugged all nowt.Unplugged from the mobo nowt.
    Will a psu fan still turn,if not plugged in to the mobo.
    Please help.Digital pint's for any reply's:D
    Cheers Jed
  2. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    PSU is independent of mobo - Sounds like a dodgy PSU though :(
  3. Sgt.Colon
    Sgt.Colon
    Would have to disagree Lex. Just make sure that you have your power on switch on the right jumper on the motherboard Jed.
  4. elneckio
    elneckio
    Dec 30, 2002
    38
    Standing on head
    On ATX - No because the 'wakeup' goes through the main connection.
    To debug this problem... Remove everything except the PSU, MotherBoard, GFX Card, CPU & Heatsink/Fan, Memory and Power on switch cable. If the PSU fan doesn't power up in that configuration then it is probably a duff-psu, although it could still be the motherboard but that would be very unusual.
  5. elneckio
    elneckio
    Dec 30, 2002
    38
    Standing on head
    Thinking about it it could also be the power on switch.
  6. HMHB
    HMHB
    Nov 11, 2001
    26,847
    Nottinghamshire
    +5,623
    Some motherboards have a jumper which needs to be removed before you can get anything to work. Not sure if this would cause the power not to be on though. It's worth checking the manual to see if there's a jumper that needs removing.
  7. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    If the mobo power light wont come on, it is fairly safe to put the psu at the top of the list...... any problems I have ever had, the mobo power light has always been on..... virtually the only problem i havent experienced is a psu problem.....
    good luck with sorting it!
    ad
  8. minimad
    minimad
    That jumper is the CMOS reset jumper. Most new mobos ship with this set to "Clear" and it needs to be set to "Normal" for the PC to operate.
    I have fallen fowl of this many time - the first time I even drove back to the selling company to complain! How embarrassing was that???
  9. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Any idea what mobo's they are.
    The one i have is a
    MSI KT3 ULTRA R
  10. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I dont mean to give a conflicting view....... well actually i do! But surely if it was simply the jumper then Jed should at least be getting a mobo power light and he should definitely be getting the psu moving into action?
    Is having the jumper set this way a new thing....... i can honestly say ive never before come across it
    ad
  11. Sgt.Colon
    Sgt.Colon
    Jed.
    Without trying to power up, when you plug the power lead in do you get any lights on your mobo at all?
  12. Jed
    Jed
    Aug 20, 2002
    4,087
    71
    +35
    Sorted it.
    I put the PSU from my good computer,in to my new one and it worked.So it's the PSU
    Thanks for all your help.
    Cheers Jed
  13. minimad
    minimad
    Good news. Have Fun.
    Was it a new case? If so can you not take the power supply back and moan at the shop?
    Collin
