Probs with AVC-11SR remote.....pls help
Discussion in 'AV Receivers & Amplifiers' started by oreoboy13, Mar 3, 2002.
  1. oreoboy13
    oreoboy13
    I took delivery of my first Av amp yesterday and although i have to wait 2 weeks for Sevenoaks to get the rest of my euipment in, i have been playing with the amp in 2 channel, btw its very impressive with music.
    Anyway the remote doesnt seem to be behaving itself, the Volume works, the dsp modes works, but i dont seem to be able to change the source or turn it on from the remote.
    Any ideas or am i being dunce :)
  2. rnjones
    rnjones
    Does the LCD display say amp? I think the volume will work which ever component you are controlling. As this is a learning and multi device remote (and as ugly as sin), you can select which device you are controlling. THe LCD display indicates which thing it is selected to control.
    Set it to AMP and everything should work. If it already is I have no idea.
    Rog
  3. oreoboy13
    oreoboy13
    Thanks to you its now working. :)
