Problems !!!!!!!!
Discussion in 'AV Receivers & Amplifiers' started by gunnerboy, Mar 26, 2006.
  1. gunnerboy
    gunnerboy
    Dec 13, 2005
    345
    Kirkconnel
    +14
    My denon AVR2106 is playing up. It was all working fine - then !
    When I have my dvd player hooked up to the amp via component and digital optical - I get a picture but no sound.
    I also have my xbox 360 hooked up to the amp via component and digital optical - works fine.
    I have swapped them around to see if there was any problem with the bits of kit or cables - everything works ok.
    The problem seems to be that when I press the "DVD" button on the remote (showing on the amp display as dvd in ) - there is no sound.
    Sound comes through on the other input channels - just seems to be the "DVD" in ??????????
    The component switching works fine.
    I have tried using all 3 optical inputs on the amp - reassinging them to "DVD" - but to no avail - still no sound.:suicide: :suicide:
    Ideas guys :lease: :lease: :lease:
    Or could I be looking at a dodgy switch in the amp - return to shop ?
    :lease: :suicide: :lease: :suicide:
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    I'd be looking at the output of the DVD, myself.
    Have you been playing with the settings :nono: ;)
  3. gunnerboy
    gunnerboy
    Dec 13, 2005
    345
    Kirkconnel
    +14
    I have hooked up the dvd to the amp - but using the "TV" input switching on the amp - via component and optical.
    Working fine - picture and sound.
    It appears to be the switching on the amp when trying to use the "DVD" input.
  4. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,923
    Strange.
    I'd hoof it back in that case :smashin:
  5. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    Make sure that the DVD input is set to "auto".
    On my 3802, this is done with a pushbutton on the front panel.
    It may currently be set to "analogue", so would be ignoring the digital input.
  6. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    if the x-box gives sound from its optical connection to the amp, then simply unplug the optical cable at the x-box end of the cable, plug that in to the DVD player and see if you get any sound, obviously you wont get picture, but thats not important, this will tell you if the DVD player is at fault or not as you know the x-box is working ok.....
    (so make sure btw that you put something in the DVD player that has sound immediately upon playing...lol)
    edit: whoops, didnt read the post about it working on the TV input....my bad...heh, ignore my post...lol)
  7. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    I don't know the Denon amp, but I'm sure there is a mechanism to set the Denon back to the factory default settings. I would try that before fault finding any further. It may be that the amps processor has got confused.
