CP-PC
Established Member
ive just changed motherboard and graphics card in a pc but cpuz is picking the processor us as an intel e2220 but its also picking it up as an e2200 (on the same page)
the processor is an e2200 and was picked up as this on the old motherboard.
another problem is the temperature i have an arctic cooling freezer 7 pro (PWM version) . HW Monitor is picking up 3 temperatures for the CPU one is the surface temp (45C) and two are the core temperatures which are at 37C while under low load (web surfing and playing music)
i have verified the core temperatures with core temp and they are fine but why is the surface temp higher than core??? faulty sensor???
just to add...... HW Monitor picks the CPU up as an e2220 aswell.
processor is picked up as an e2200 in bios..... FSB and Multi are set correctly and its running at 2.2ghz (stock, with stock voltage too)
also on a side note...... STR (S3) wont work. it turns off and within a second its back on again ..... this is with a clean install of vista ultimate 64bit with nothing else installed..... not even the motherboard driver cd
motherboard was a Foxconn P4M9007MB-8RS2H with an ATI X700
thats been taken out and replaced with
an ASUS P5B and an XFX 8600GT Extreme OC
everything else is the same... psu, case fans, hard drive, ram, dvd-rw drive even the case.
just incase you need to know the psu is a Hiper 480watt with a 120mm fan
case fans are two 120mm akasa fans that came with the case (akasa zen black) hard drive is a maxtor ide133 160gb 8mb cache
ram is 2x1gb sticks of OCZ 800mhz dual channel ram. and optical drive is a pioneer#
i have attatched a picture and highlighted the important bits in red. the temperatures are higher than what i stated above because when i took the screen shot i was runing folding at home on the cpu and gpu. but you can still see the surface them higher than the core temps
thanks in advanced guys
