Problems With Yamaha a5
Discussion in 'AV Receivers & Amplifiers' started by ChrisB, Dec 25, 2000.
Tags:
  1. ChrisB
    ChrisB
    Please help
    im trying to get dolby digital playback through my a5. i have connected my dvd player via composite cable to the digital input on the amp. the dvd player (a wharfdale 750s) says it is reading dolby digital but it only registers pro-logic on the amp. it plays dts fine???
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    Have you?-
    1. Made sure the DVD disc menu audio output is set to DD?
    2. Does the amp have an auto/manual audio selector on it to determine what you hear?
    3. Has the player been set to output DD?
    Maybe muppet questions, but things easily overlooked.
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
    [This message has been edited by General Skanky (edited 30-12-2000).]
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Composite cable? for digital audio? Either you have the wrong cable or you are calling it the wrong name. For digital audio ie Dobly Digital or DTS you need a Digital Coaxial or a TOS-link cable (fibre) depending on what the Amp and DVD player supports.
  4. Guest
    I had this problem as well but with the RX-V596. Check that the output from the DVD is set to Bitstream not PCM, I think that is the correct way around. Otherwise try it the other way around. This is configured in the setup menu.
