Problems with xbox 360 controller on windows
Discussion in 'Xbox Forums' started by yinujim, Sep 16, 2007.
  1. yinujim
    yinujim
    Jul 7, 2006
    1,097
    East London
    +52
    I installed the software for the xbox 360 wired controller, and then connected it to the PC and you get the 'found new hardware' after that it shows a request for the 'xusb21.sys' for 'xbox 360 wireless reciever for windows install disk needed'
    Help:rolleyes:
  2. m1ket
    m1ket
    Aug 24, 2005
    3,694
    UK
    +332
    Is that windows xp?
    Only saying because i plugged my wired controller into vista and it worked with no install at all
  3. yinujim
    yinujim
    Jul 7, 2006
    1,097
    East London
    +52
    Yes its an XP
  4. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,621
    +6,604
    You need either the official Microsoft driver or the XBCD driver
    I use the XBCD driver
  5. yinujim
    yinujim
    Jul 7, 2006
    1,097
    East London
    +52
    Still comes up the same message and XBCD has a blank box next to device
  6. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    This might sound silly but it is the official wired controller you're trying to use ?
  7. yinujim
    yinujim
    Jul 7, 2006
    1,097
    East London
    +52
    Yes
  8. yinujim
    yinujim
    Jul 7, 2006
    1,097
    East London
    +52
    Fixed
  9. lovelldr
    lovelldr
    Jul 19, 2006
    2,287
    63
    East Midlands
    +148
    might help to explain how, what the problem was, so that if someone else has the same problem and does a search, they can fix it without having to ask...
  10. gameenthusiast
    gameenthusiast
    Aug 12, 2009
    12
    4
    hey
    the official MS Drive is your solution
    ^_^
