problems with xbmp
Discussion in 'Nintendo Forums' started by H4r7y, Jul 3, 2004.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    im trying to play some avi files on my xbox, but when i load up xbmp, it comes up with the discs name, but when i press (A) then the screen goes black and ive waited over 5 mins for it to load but in the end i have to reset the machine and it wont work.
    is there anything i have to install ie, codecs or something?
    this is the first time im using it and its the one that comes on the slayers auto installer disc.
    is there a chance it could be the actual disc ive got? could it be the way its been encoded that the xbox wont recognize?
    cheers
  2. mitch
    mitch
    Sep 6, 2003
    5,450
    +662
    try using xbmc instead.i find it plays everything i throw at it.xbmp is a bit outdated now and is not supported with updates like xbmc
  3. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    cool, thanks mitch ill give it a look into, see if i can get it installed without ftp
    cheers
  4. mitch
    mitch
    Sep 6, 2003
    5,450
    +662
    try looking for x-disk 101 ;)
